symptoms of a bent clutch fork
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scratchy »</TD></TR><TR><TD CLASS="quote">CLUTCH DOESN'T WORK WEIRD RIDDING NOISE WHEN YOU ARE THE CLUTCH</TD></TR></TABLE>
Caps lock is key.
Caps lock is key.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">
Caps lock is key.</TD></TR></TABLE>
I'm also a big fan of punctuation.
Anyway, are you wondering because you think yours might be bent? If so, let us know the symptoms you are running into.
I'm also a big fan of punctuation.Anyway, are you wondering because you think yours might be bent? If so, let us know the symptoms you are running into.
the 3 other replies ive seen from him were all in caps
my friend had a bent fork on his lude. had a lot of trouble changing gears sometimes wouldnt even go into reverse. Had to try a few times before it went into gear. Turned out the honda tech forgot to put the tranny fluid in and, Honda had to buy him a new tranny. The fork i belive pulls the clutch disk away from the flywheel when you press on the clutch pedal.
the clutch & pressure plate could be totally screwed up. that was my case and i was experiencing similar problems. i had swore it was the clutch fork, but wound up that there were parts taken out of the clutch and the pressure plate was kinda melted a little. nitrous caused my problems, but i expected it after an old stock clutch.
Don't mean to bring this thread back up but my wife's 91 civic stopped going into gears one day so I replaced clutch and new clutch cable then found out her clutch pedal was broken Soni fixed every thing but the fork has alot of play I can't adjust cable cause it maxes out. Does this sound like a bent fork?
one slow coupe
19
Jan 10, 2005 08:46 PM
