Thermostat Plug for B16A
Old Jun 22, 2004 | 12:14 PM
nousername's Avatar
Default Thermostat Plug for B16A
Hey all,
I've searched and didn't come up with a conclusive answer.
I've got a B16A swap I just picked up, I was moving the wire harness over from my 91 CRX SI + the sub-harness from Hasport and managed to match up all plugs except for the thermostat plug on the B16. The plug is located above the thermostat and is brown. Did I miss a plug or is this something that needs to be spliced into my wiring harness.
Any help would be appreciated. I'm at work right now, if you need pics maybe I can get them up later. Thanks!
m
Old Jun 23, 2004 | 05:45 AM
nousername's Avatar
Default Re: Thermostat Plug for B16A (nousername)
N E 1?
Old Jun 23, 2004 | 07:10 AM
APEX CRX's Avatar
from what I remember, depending on your Gen B16 you will have to extend the 2 wires from the old harness. It went to the back of the block on the D-series and you will have to splice on the correct 2 pin plug
Old Jun 23, 2004 | 07:31 AM
nousername's Avatar
Default Re: Thermostat Plug for B16A (APEX CRX)
thanks for the info!
m
PHC406
Jan 25, 2015 01:04 AM
sonic47
13
Feb 10, 2010 03:23 AM
thapimpfromchi
11
Mar 8, 2006 04:36 AM
user 72830283
13
Sep 18, 2005 12:20 PM
