Great compression, but still burning oil HELP!!!
Old Jun 22, 2004 | 11:10 AM
Layziebtnh055's Avatar
Default Great compression, but still burning oil HELP!!!
i did a compression test all four cylinders were around 240, the spark plugs had oil on the threads and they were black, what is cauing the oil to burn please help!!
Old Jun 22, 2004 | 11:14 AM
DXDOHCVTEC's Avatar
sounds like it may be the valve guide seals...?
Old Jun 22, 2004 | 11:20 AM
FourthGenHatch's Avatar
Default Re:
Is oil getting into the cylinders? If so that will give you good compression since the oil is creating a seal.
Old Jun 22, 2004 | 11:26 AM
DXDOHCVTEC's Avatar
Default Re: Re: (FourthGenHatch)
^ Tru. Oil must be getting in the cylinder because it is "burning" it. Also he says it is on the plug threads, but when you do a compression test there shouldnt be any oil to seal the rings unless YOU put it in there.
Old Jun 22, 2004 | 02:01 PM
CRXracer88's Avatar
maybe the oil ring is bad...
Old Jun 22, 2004 | 03:25 PM
MENACE's Avatar
Default Re: (CRXracer88)
Yeah if the plug were wet with oil your gonna have good compression. Sounds like Rings to me. normally oil in the combustion camber wont cause the vavle seals to seat any better, it it will make a nice tight seal on the rings.
jonyi27
Apr 21, 2014 11:55 AM
blackeg
Jun 20, 2013 03:13 AM
eg:R
Jun 4, 2009 08:10 PM
Nicks95GSR
Sep 28, 2007 10:54 AM
DarkDragon
Oct 28, 2005 04:15 PM
