Plug wires???
Old Jun 22, 2004 | 10:29 AM
eg64u's Avatar
Default Plug wires???
which ones do you guys run? ANd also im looking at either the ngk power cable and msd super conductor 8.5mm. The ngk on a dyno gave about 3 hp over stock and msd gave about 4 over stock. I want the msd but its kinda pricey, i was wondering were is the best place on the net besides ebay to buy these at for cheaper?
thanks
Old Jun 22, 2004 | 10:38 AM
mmuller's Avatar
Mad Scientist
Default Re: Plug wires??? (eg64u)
i dunno, but i think oem honda is the best, it has been tested over anything and proved to be more consistent.
Old Jun 22, 2004 | 10:41 AM
eg64u's Avatar
cool yea thats what ive heard too,, but if i can get 3 hp for 40 over stock i will do it.. also how much is oem wires vs ngk general blues?
Old Jun 22, 2004 | 12:48 PM
kommon_sense's Avatar
Default Re: (eg64u)
NGK or oem. The NGKs are around the same price, maybe a few bucks cheaper than the oem wires.
http://www.tprmag.com/issue/4/4_wires.shtml
Old Jun 23, 2004 | 07:26 AM
eg64u's Avatar
yea thanks for the reply, does anyone know were to get the ngk blues for cheap? I think imnog gonna spend the extra money for ngk power cables or msd supers.
Old Jun 23, 2004 | 08:41 PM
Big Teggie's Avatar
Default Re: (eg64u)
OEM or NGK work really good. I have aset of NGK's on my car now and I like them alot better than the MSD wires I had.
You can get NGK's at Sparkplug.com. You can also find they at some Napa's.
Old Jun 24, 2004 | 04:51 AM
MightyMouseTech's Avatar
Default Re: (Big Teggie)
I will only use OEM. They are usaully good for 300k+ and always fit perfect.
Old Jun 24, 2004 | 06:59 AM
91civicDXdude's Avatar
I had a set of MSD 8.5's on my old d16z6. As far as performance, i had no complaints, although MSD does have a nasty problem about slipping off of the distributor. Myself and 2 friends have had this same problem.
Old Jun 24, 2004 | 08:32 AM
eg64u's Avatar
thanks for the replys i will be picking up some oem or ngk's soon
Old Jun 24, 2004 | 11:02 AM
Big Teggie's Avatar
Default Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">I had a set of MSD 8.5's on my old d16z6. As far as performance, i had no complaints, although MSD does have a nasty problem about slipping off of the distributor. Myself and 2 friends have had this same problem.</TD></TR></TABLE>
I had the same problem with the MSD's coming off the distributor.
Old Jun 24, 2004 | 11:06 AM
Actually, why are you replacing the wires in the first place. I find the OEM's are good for 2-300k or 12+ years. Spray them down with water and measure the resistance, if the car does not sputter with the water, and the resistance measures OK, then you are wasting your money by replacing them.
Old Jun 25, 2004 | 12:22 PM
eg64u's Avatar
i am in need of one wire actualy im rolling with 2 of the same wires and the other 2 are different because one wire was fuc$#. So one wire is sticking out were the distributor is like a bit$# and its dangling and i just want it clean. SO unless they can sell me 1 only at honda/acura then im just gonnna buy a new set
deebeeate
Jan 18, 2013 01:41 PM
ramz7887
80
Apr 14, 2004 12:56 PM
BassBoy19
Apr 13, 2004 11:33 AM
MooreBoost
Sep 28, 2002 07:58 PM
Jul 26, 2002 11:10 AM
