idle jumps like a mofo from 1000 to 3000
Old Jun 22, 2004 | 09:06 AM
cxjon's Avatar
Default idle jumps like a **** from 1000 to 3000
i put in a new fuel filter, plugs, wires, cap and rotor to see if that would help but it doesn't, so i was told to take my aic off and spray that with carb cleaner but that was no help. there is no cell light and my ecu is not throwing codes. the throttle cable is fine.. any ideas
Old Jun 22, 2004 | 09:48 AM
pdiggitydogg's Avatar
did you try cleaning the entire IM?
(edit** spraying tb cleaner into the tb w/ the car running)
Old Jun 22, 2004 | 09:53 AM
crx_88_si's Avatar
sounds like u hit a vac hose.. double check all.
Old Jun 22, 2004 | 09:58 AM
krazn's Avatar
Default Re: (crx_88_si)
friend is having the same problem..except he is throwing code 14 and 41. if ur not throwing a code...it mite be a dirty TB. check ur hoses again too.
Old Jun 22, 2004 | 10:12 AM
cxjon's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">?
(edit** spraying tb cleaner into the tb w/ the car running)</TD></TR></TABLE>
i never heard of that
Old Jun 22, 2004 | 11:54 AM
cxjon's Avatar
Default Re: (cxjon)
bump
Old Jun 22, 2004 | 11:59 AM
just like the can says to do
essentially youre putting carbon remover through the engine...its like a very mild seafoam that way...and cleans the tb
Just turn it on, spray some cleaner in and have someone feather the throttle so it doesnt die (or you can pull the cable under the hood)
I did that the same day I cleaned the iacv (which didnt solve the problem) and the idle was fixed.
Another option...when's the last time you changed the pcv?
Old Jun 22, 2004 | 12:00 PM
Matty.'s Avatar
Default Re: idle jumps like a **** from 1000 to 3000 (cxjon)
You didn't mention anything about your coolant, but the idle will jump like that if you have an air bubble in the coolant system sometimes.
just another option.
Old Jun 22, 2004 | 12:50 PM
EkDave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">sounds like u hit a vac hose.. double check all.</TD></TR></TABLE>
I had the same problem after changing my stock GSR manifold out for the Skunk 2 one. I'm going to bet on the Vacumme lines.
Old Jun 22, 2004 | 01:03 PM
scratchy's Avatar
IDLE AIR CONTROL VALVE JUST UNHOOK IT AND SEE IF IT STOPS IT WILL THROW A CODE BUT SHOULD FIX THE IDLE THEN TAPE IT OFF AND IT SHOULD TAKE CARE OF YOUR PROBLEM OR GET A NEW ONE THEY ARE LIKE 200 BUCKS
Old Jun 22, 2004 | 01:26 PM
EE_Chris's Avatar
Unplug your IACV: What does the idle do/settle to?
Have you messed with the idle air bypass screw or the throttle plate stop screw?
Old Jun 22, 2004 | 01:30 PM
letholone's Avatar
also check your throttle adjustement screw(the large flat head one on top of the TB) this happened to me for a few days, and it was just that my screw had become too loose.
Old Jun 22, 2004 | 01:31 PM
poison's Avatar
Remove the plate held by two 8mm/phillips bolts located underneath the TB. Tighten the white spring loaded valve by turning it clock wise all the way.
Check the idle screw on top of the TB as well.
That should fix your problem unless your IACV is bad.
Old Jun 22, 2004 | 02:33 PM
cxjon's Avatar
Default Re: idle jumps like a **** from 1000 to 3000 (poison)
my pcv valve is new and still rattles, i should add that it makes a sucking sound aswell
Old Jun 22, 2004 | 02:35 PM
cxjon's Avatar
Default Re: idle jumps like a **** from 1000 to 3000 (gumtape_deathmatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gumtape_deathmatch &raquo;</TD></TR><TR><TD CLASS="quote">You didn't mention anything about your coolant, but the idle will jump like that if you have an air bubble in the coolant system sometimes.
just another option.</TD></TR></TABLE>
i checked that its full....
Old Jun 22, 2004 | 04:05 PM
cxjon's Avatar
ttt
Old Jun 23, 2004 | 12:35 AM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">Remove the plate held by two 8mm/phillips bolts located underneath the TB. Tighten the white spring loaded valve by turning it clock wise all the way.
That should fix your problem unless your IACV is bad.</TD></TR></TABLE>
Once again.
tegra2G
Feb 12, 2011 08:07 PM
Hill4589
12
Feb 10, 2010 03:49 PM
nexepisode
Nov 22, 2005 04:45 AM
Ur 2 Slow 4 J
Oct 12, 2005 08:34 AM
girlie
Mar 6, 2003 09:58 AM
