just got done reading my turbos compressor map...NEED A 2ND OPINION!
i have just got done reading the compressor map for the h-3 wheel
now after ploting specific RPM points...
i found out that at 18 psi , w/ my motor (132cid) h22a4
that the compressor will be going into surge until about 5500 rpms..
now i know for a fact that the turbo will reach 18psi WAYYYY before 5500 rpms
specs on the turbo are as follows:
t3/t4B h-3 comp. trim w/ .63a/r and stage 3 exhaust..
here's is the h-3 compressor map..
if someone can give me a second opinion...maybe i did something wrong
please help before i spend $800 on a new turbo
Modified by graphic at 5:35 PM 6/23/2004
I'd skip that one. It is not sized correctly for your car. Your gonna end up with a weird looking transition in your fuel curve from vacuum to boost because of the huge surge of air. (talking from experience with the h-3
besides a wierd looking fuel curve...is there anything else..
like driveability issues because of the wierd looking fuel curve?
i am particularly worried about surging...
i spoke to a turbonetics rep and he said i need MAD boost...in order for it to surge down low
doesn't 18psi qualify as MAD boost??
plot it and it surges until 5,500 rpm
