pre-oiling/lubing new motor
Old Nov 16, 2001 | 06:52 AM
rtype11's Avatar
Default pre-oiling/lubing new motor
does anyone have a good way to preoil the oil pump, like a domestic they can use a drill where the distributor goes to spin the pump and lube everyting up prior to running.
Old Nov 16, 2001 | 08:19 AM
Speed PHreak's Avatar
Default Re: pre-oiling/lubing new motor (rtype11)
Well during the assembly of engine components I usually use that STP oil additive stuff, it's thick and coats the componets well. Dunno about priming it like you're talking about, you could try and spin the oil pump cog/gear. If you coat it well enough prior to re-assembly. You should be able to spin it over a couple of times and get the system pressurized....(ecu fuse dissconected so that it doens't start).
When I installed my cams I put white lithium grease on them, but they're not in the combustion cylinder........
Old Nov 16, 2001 | 08:22 AM
TurboInteg95's Avatar
Default Re: pre-oiling/lubing new motor (Speed PHreak)
I use redline assembly lube on all components when I'm building a motor. If a god amount of assembly lube is used you can start it right up with no problems.
Old Nov 16, 2001 | 09:03 AM
MackSpeed-616's Avatar
Default Re: pre-oiling/lubing new motor (TurboInteg95)
exactly.. there should be enough assembly grease on the bearings during the build to sustain a few seconds without oil...
Old Nov 16, 2001 | 01:22 PM
b18bturbo's Avatar
same thing i use.. excellent product
92integraVTECgsr
Jan 28, 2007 08:25 PM
kerby116
Mar 1, 2004 03:34 AM
Prelude Vtec 23
May 5, 2003 07:52 AM
JD_B18CDX
Nov 28, 2002 12:15 PM
johnzm
Aug 11, 2002 09:25 PM
