Weird vacuum problem in head
Old Jun 22, 2004 | 05:41 AM
Another B16's Avatar
New User
Default Weird vacuum problem in head
Just installed turbo pistons, rods etc. Now it has a lot, 10-15 PSI vaccum coming from the valve cover gasket when runnning at idle. It is sucking through the valve cover breather. Anyone ever heard of this? Did I install a vacuum line wrong? What could cause that much vacuum in the valve cover? Thanks.
Old Jun 22, 2004 | 06:44 AM
crx_88_si's Avatar
uhm. . that valve cover "breather" is an air inlet for the PCV system.
Old Jun 22, 2004 | 07:34 AM
MENACE's Avatar
Default Re: Weird vacuum problem in head (Another B16)
Um im Pretty sure the motor should be pushing air out frome that hole. But really i dont see a problem only because you system works better. You dont have positive crankcase pressure, you have negative crankcase pressure. I dont see how that can be bad because the Pcv system only releaves that pressure. If you dont have it then you should be fine.
Also did you check it once the motor is spinning faster sometimes they can be positive at idle but once you rev it some, They start making some vacuum.
Hope that made sense to ya.
Old Jun 22, 2004 | 07:44 AM
crx_88_si's Avatar
no its an air inlet.. the outlet goes thru the PCV valve into the intake manifold.
Old Jun 22, 2004 | 07:53 AM
MENACE's Avatar
Default Re: (crx_88_si)
O Dam your right. OK well next thought like i said theres not that much pressure at idle so the PCV system is just pulling more air. But basically you should a positive pressure at some point while going threw the revs. the Pcv system works good but they dont keep up very good at high RPM's. Basically everything is fine like i said it just means its workin very good at idle.
Old Jun 22, 2004 | 07:57 AM
MENACE's Avatar
Default Re: (MENACE)
Ok let me clear up my Contridiction Very high RPMS you should have a slight positive pressure. Low RPM's its fine to have alot of negative pressure. Just ignore My first post, I was confused and thinkin the system basically works backwords.
Old Jun 22, 2004 | 12:52 PM
New User
Thanks, I'll check it tonight. I've only checked idle so far.
Acura_I-RS
Oct 25, 2005 01:55 PM
LSVTEC 91 Civic
Jul 30, 2005 12:47 PM
pwrofdrm
Mar 21, 2005 07:06 PM
hackish
May 10, 2004 05:00 PM
Ivan
Jun 27, 2003 04:37 AM
