Rear sway bar
Old Jun 22, 2004 | 03:38 AM
adi69's Avatar
Default Rear sway bar
Hi,
This is my first post from here in the UK.
I'm trying to find out about the rear anti sway bar on the different generation and body types of Civics.
I have a 5 door MA VE9 VTI......which I don't think was released in the US. It is an EK 1.8 VTI (169bhp).....but the problem is the rear sway bar was bolted to brackets bolted to the rear chassis legs........rather than just above the lower arm mounting points.
What I'm trying to find out is.......
1. is there any way of fitting the Integra Type-R 22mm rear sway bar........which bolts in the normal way, just above the rear lower arm mounting points or
2. is there a larger rear bar than the std 18mm bar that fits on the existing mounting points.
I hope this doesn't sound really confusing.....if I knew how to post a piccy, It'd make things a bit clearer.
Old Jun 22, 2004 | 03:42 AM
92b16vx's Avatar
Should be pretty much like all the other Civics. It's been a while since I was under a MA, but I can look around.
Old Jun 22, 2004 | 11:09 AM
adi69's Avatar
Default Re: (92b16vx)
From what I can see......the MA is similar to the CRX......in that the brackets holding the sway bar......are hanging from the chassis legs.....rather than bolted to the rear of the lower arm mounting points like the Integra and EK Civics.
kulo
Suspension & Brakes
Oct 2, 2012 12:06 PM
phat00civic
Suspension & Brakes
19
Jan 13, 2012 01:51 PM
Charlie Moua
Nov 9, 2011 10:00 AM
Dorikamu
Oct 25, 2002 01:01 PM
