electrical problem-DRL
Old Jun 22, 2004 | 12:59 AM
clyde_bossman's Avatar
Default electrical problem-DRL
i have a 96 accord. i have a problem with my DRL and high beam. i dont know how it usually works but this is what happens. when all the light switch is in off position, the DRL(orange) and high beam(blue) indicator icons are lit. then i check the front lights, no DRL are lit. however, when i turn the head lights on, both the indicators are unlit. when i switch my headlights to high beam, only the left high beam light, but the right one doesnt. with this on hand, i replaced my high beam light ( i think its the HB3). but it still does same problem. i am sure the one i bought works.
how can i fix this, is there a problem with my relay, what relay and where? are the wires grounded? if so, how do i trace it? what is the reason for this.?
thank you in advance for your reply.
Old Jun 26, 2004 | 10:52 AM
GrafxDesignGuy's Avatar
Default Re: electrical problem-DRL (clyde_bossman)
You have the OEM DRL? or did you do a conversion.
If you were messing with the wires to do the DRL conversion on a USDM Accord remember that headlights are usually ground triggered.
Sounds like you got some crazy cross wiring going on. My suggestion: get a headlamp wiring diagram and put everything back to stock and start what ever you were trying to do over again. Good luck.
Old Jun 26, 2004 | 01:14 PM
philadd's Avatar
Default Re: electrical problem-DRL (GrafxDesignGuy)
he didn't do a conversion... canadian models have drl's already. well, at least for 6th gen... i THINK they did in 96 too...
pitcrawler
Oct 3, 2017 05:57 AM
OG Wagon
Lighting
Oct 10, 2014 10:29 AM
Maguyver
Aug 1, 2010 05:34 AM
471r
Honda Civic (2001 - 2005)
Jul 13, 2010 10:18 AM
elnoyl
Sep 30, 2009 12:04 PM
