Bleeding Clutch on 98 GSR
Old Jun 21, 2004 | 10:13 PM
radio1global's Avatar
Default Bleeding Clutch on 98 GSR
Can anyone tell me exactly how to do so , and where on the tranny is the actual bolt that comes loose? thanks ahead of time.
Old Jun 22, 2004 | 03:09 AM
Lscivichatch92's Avatar
Default Re: Bleeding Clutch on 98 GSR (radio1global)
ok,
1. you go buy a haynes manual.
jk
1. you add brake fluid to the clutch master cylinder resivoir (SP) and make sure it stays full
2. locate the bleeder valve on the slave cylinder, its right next to ur header on the front of the tranny, u cant miss it, its an 8mm by the way
3. then you get a buddy to pump the clutch over and over again to build pressure, then tell him to hold it down, then you open the bleeder valve for a second and let the brake fluid come out only for a second tho, then you close it up and then you can tell your friend to pump the cluch again. IT IS VERY VERY IMPORTANT THAT YOU KEEP THE BRAKE FLUID FILLED AT ALL TIMES AND THAT YOUR BUDDY HAS THE CLUTCH HELD DOWN WHILE YOU OPEN AND CLOSE THE VALVE. ONLY PUMP WHEN THE VALVE IS CLOSED.
4. when you regain full clutch pressure, your done.
ps. you might have to do it a few times to get all the air out of the line.
starquestchris
Mar 23, 2010 10:25 AM
924doorEG
Jul 16, 2007 05:31 AM
g_rant2006
Sep 13, 2006 09:46 AM
thaimonkey
Jul 12, 2005 12:39 PM
carblegal
Mar 24, 2003 08:24 PM
