piston to valve clearance
Clay the head and find out. It's a really good idea if you are concerend with clearence. It will tell you what room for improvement you have down the road IE overlap, duration, lift. But yeah it will work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master »</TD></TR><TR><TD CLASS="quote">Clay the head and find out. It's a really good idea if you are concerend with clearence. It will tell you what room for improvement you have down the road IE overlap, duration, lift. But yeah it will work.</TD></TR></TABLE>
if i clay the motor, wouldn't that involve ruining a head gasket? because don't you have to torque down a couple of the head bolts and obviously there hast o be a gasket in there for correct readings...
Some head gaskets you can get away with torquing and reusing, but I would recommend getting another for the build. You have to torque down all the head bolts. It will tell you how far you can go before its a worry though.
Having an ls crank does not change the amount of piston to valve clearance you have, havning non-vtec pistons where the reliefs are hardly cut-- does. My old nA setup had portflow valvesprings / stock retainers, jun3s, b16 pistons / stock gsr rods. revved to 9500. late. the only way yours will be different is in that your rods are going to stretch more, but this won't be an issue if you upgraded the bolts (did you?).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr »</TD></TR><TR><TD CLASS="quote">your rods are going to stretch more, but this won't be an issue if you upgraded the bolts (did you?).</TD></TR></TABLE>
obviously
obviously
Just put it together, crank it, engage vtec and see if you hear anything....actually, you should be fine with stock cams(when you get stage IIIs you might need to clay though).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr »</TD></TR><TR><TD CLASS="quote">Having an ls crank does not change the amount of piston to valve clearance you have, havning non-vtec pistons where the reliefs are hardly cut-- does. My old nA setup had portflow valvesprings / stock retainers, jun3s, b16 pistons / stock gsr rods. revved to 9500. late. the only way yours will be different is in that your rods are going to stretch more, but this won't be an issue if you upgraded the bolts (did you?).</TD></TR></TABLE>
what he said
what he said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra »</TD></TR><TR><TD CLASS="quote">Just put it together, crank it, engage vtec and see if you hear anything....actually, you should be fine with stock cams(when you get stage IIIs you might need to clay though).</TD></TR></TABLE>
i quoted ur post but, what the hell is that buzzing sound from the abs?!!?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 »</TD></TR><TR><TD CLASS="quote">
i quoted ur post but, what the hell is that buzzing sound from the abs?!!?</TD></TR></TABLE>
abs pump re-circulating
Carlorec96
Jul 21, 2018 05:59 PM
ehrkeith
10
Apr 16, 2012 05:54 PM
EG6 Love
Feb 16, 2010 06:25 PM
Ryan15
Sep 15, 2006 09:58 PM
Irishweird00
May 22, 2004 08:26 AM
