Zdyne people.. Just put in my 3 bar map, running real rich, what to adjust
Old Jun 21, 2004 | 04:12 PM
boosted_zc's Avatar
Default Zdyne people.. Just put in my 3 bar map, running real rich, what to adjust
Just as the topic states, i wrote a great program for my turbo'd ZC but wanted to boost more so i put in my 3 bar map. Now it runs crazy rich, tried changing the volts and taking more fuel out of the map and it didn't seem to help, so any suggestions are welcome. Thanks
Old Jun 21, 2004 | 04:24 PM
sporkcrx's Avatar
Default Re: Zdyne people.. Just put in my 3 bar map, running real rich, what to adjust (boosted_zc)
Did you go into the settings with F3 and make sure it's set for a 3bar?
Old Jun 22, 2004 | 01:52 PM
boosted_zc's Avatar
Default Re: Zdyne people.. Just put in my 3 bar map, running real rich, what to adjust (sporkcrx)
yes it's setup for 3 bar.
Old Jun 23, 2004 | 02:37 AM
86si's Avatar
what size injectors are you running?make sure your map is wired correctly
Old Jun 23, 2004 | 12:59 PM
boosted_zc's Avatar
Default Re: Zdyne people.. Just put in my 3 bar map, running real rich, what to adjust (86si)
The injetors are 550's, but your not understanding something. It ran fine on the stock map with my 550 program. I put the 3 bar in and switched the program to a 3 bar map and it runs real rich. Now i need to know what to adjust.
Old Jun 23, 2004 | 02:28 PM
86si's Avatar
If you are using a b16 3bar file,.550 injectors are 20% larger than the 450 table.Highlight the entire fuel table and take out 15% to be safe and it should be good.
Old Jun 24, 2004 | 03:51 PM
boosted_zc's Avatar
well first off using a b16 file on a ZC would just be silly. I'm well aware of the 20% deal. If you'd read below, the program i wrote FOR THE 550's runs great with my stock map, BUT when i change the program to a 3 bar it runs extemely rich at idle, and i have it at the lowest fuel pulse setting the program will allow. So the question is why the 3 bar is making it run richer and how to lean it out without taking fuel out of the map cause i can't take anymore out. Are we on the same page now.
Also just incase you ask the fuel pressure is at 30psi at idle, the lowest i can put it with my AEM.
Old Jun 24, 2004 | 04:57 PM
Sack Master's Avatar
A friend of mine was using a GM 3 bar and it totally ran rich. I think he picked up a bunk one or something. Hopefully he'll chime in and let you know what his problem was becuase I believe it's fixed now.
Old Jun 25, 2004 | 11:58 AM
86si's Avatar
I am running a zc and made 311whp at 22psi with 550cc rc's.This was with a b16 file.Zdyne does not have a zc file,only b16 and pm6.I know you say it is not your map but i wirered mine wrong and it cooked my 3bar and ran way rich.I'm just trying to help bro!
jthrasher1
Jun 6, 2010 01:27 PM
acuralovar
Engine Management and Tuning
Dec 21, 2009 02:27 PM
Turbocivic94
Feb 27, 2006 09:11 AM
hybridb18
Sep 11, 2003 12:20 PM
