big clunking noise
Old Jun 21, 2004 | 01:17 PM
hOndafienD 04's Avatar
Default big clunking noise
on my 4th gen it makes this big clunking noise when i am rolling in neutral or just release the gas when im driving it.....when i accelerate or brake it no longer clunks, and it also clunks in between shifts, and the clunks get closer and closer with increased speed. i checked the suspension and its all good...i drove it on the lift and didn't make any noise, bearings aint loose or anything....axels are good (boot isn't ripped) only thing i can think of is the the axel withing inside the boot is ripped....some1 please help me, its driving me crazy....
Old Jun 21, 2004 | 01:35 PM
es_squared's Avatar
Default Re: big clunking noise (hOndafienD 04)
cv shaft maybe ? i had hte same problem i think, but it went away lol
Old Jun 21, 2004 | 03:04 PM
Das Nein's Avatar
Gear on the constant velocity drive shaft which connects to the transmission might be worn. either way, get your drive train checked out.
Old Jun 21, 2004 | 03:12 PM
Default Re: big clunking noise (Das Nein)
it went away????? ok lol....
it almost sounds like something is loose and it seems to me like its the lest side mostly.....just picked up the 2 front tires and shifted hard and everything and it didn't make the noise...i had it up to 60 mph.....i hope its the cv axel and nothing with the trans....also when i turn the noise reduces to almost nothing so that would almost lead to me believe its the axle....
Old Jun 22, 2004 | 07:13 AM
LudeyKrus's Avatar
It could be a loose set of lugs, a bolt that's loose in the suspension, a worn axle/CV joint, etc.
I've had all kinds of knocks that sounded the same, and it is something different everytime. Just start going through and checking; if you can't find anything loose, try swappin out the axles.
Old Jun 22, 2004 | 08:14 AM
kablamo's Avatar
Default Re: (LudeyKrus)
Yeah i agree, it could be a lot of things.
You say you checked the boots and they weren't ripped, but that doesn't mean your CV joints and axles are OK: i went through something similar (weird clunking noises off and on), it turns out it WAS an outer CV joint... for some reason, it had no more grease in it, it was full of water (!?!?!?!!?). the boot wasn't ripped or anything, don't ask me how that happened, but it did. water must have slowly gone in from a loose clamp, washing out the grease...who knows...
Old Jun 22, 2004 | 09:41 AM
guess i'll try the axles 1st, since i can get em for $50 rebuilt..... i'll let you guys know..
Old Jun 23, 2004 | 01:52 PM
ha! it was only a really loose tire, soo loose dat from it being loose a stud broke off and inoticed it....mothaf*ckers in my tech class aint tighten them right when we did a tire rotation.....lesson learned. "dont let your friends work on your car" or finish it up at least..
96hondaAccordV6
Apr 24, 2007 02:15 PM
FK00GSR
Jul 19, 2005 05:23 PM
munscher
Oct 14, 2004 07:45 PM
tyflip2
12
Nov 22, 2003 07:42 AM
