Starter problem...need help asap
Old Jun 21, 2004 | 01:15 PM
eric416's Avatar
Default Starter problem...need help asap
i just got finished changing the starter in my 1996 accord and now the car doesnt
start at all. i took the intake and distributor off to make room to work replaced the
bad starter and put everything back on. now when i turn the key to start, the
starter clicks a few times. Then when the key is in the on position is sounds like
rapid clicking behind the dash and the lights on the cluster go crazy. what could be
wrong??
Old Jun 21, 2004 | 01:19 PM
LookingForVTEC's Avatar
Default Re: Starter problem...need help asap (eric416)
Sounds like a dead battery!! or a loose conection to your battery
Old Jun 21, 2004 | 01:42 PM
eric416's Avatar
Default Re: Starter problem...need help asap (LookingForVTEC)
i tried jumping it , that didnt work
Old Jun 22, 2004 | 07:54 AM
eric416's Avatar
anyone else??
Old Jun 22, 2004 | 08:46 AM
bardo's Avatar
it does sound like the battery could be dead..try using the battery from you prelude and see if it works...
Old Jun 22, 2004 | 09:33 AM
haironmybiff's Avatar
check battery and all grounds.
ej1love
23
Jun 23, 2009 06:35 AM
whophlungpoo
May 29, 2006 07:39 PM
bluesaint
12
Mar 18, 2003 11:53 PM
See Are X
Mar 6, 2003 10:08 PM
Superhatch
Dec 24, 2002 02:36 AM
