B16A1 into 97 civic running, need A/C and P/S help
My friend got a B16a1 swapped into his 97 civic (bad idea).
The swap finally runs, so now we can finish up, but we don't know what to do about the a/c and the p/s.
My friend definately wants to keep both, but the shop wants 500$ to get the a/c bracket from hasport, plus a new p/s pump and lines.
What is the easiest and cheapest way to hook them up them?
Is there something we could look for in the junkyard? What would the p/s pump be off of?
Thanks for any help.
I thought that the a/c pump from his civic ex wouldn't bolt up to the Si a/c bracket?
Is there any stock bracket that would bolt up with modification?
For A/C...Your friend needs to buy a 94-95 Del Sol VTEC p54 A/C Bracket. The part number is 38930-P54-000 from Honda. You can try to look around in junkyards for a 94-95 Del Sol VTEC, but good luck.
As for P/S...I'm not sure, I took mine out. I guess you could try running the p/s pump from that motor.
Yes, my DX A/C Compressor bolted up to that bracket with all 4 bolts, instead of only 2 when you run the Si bracket. As for the compressor being the same, I think it is. Hope someone on HT can clarify if its the same or not.
Also, did your motor come with a a/c bracket? If it did, make sure you keep the idler bracket/pulley. You will need that in order to keep your a/c.
man somebody at place racing told me that if i got a 98+ teg pump and bracket that it would work. i do not know for sure. hope that helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deejayrock »</TD></TR><TR><TD CLASS="quote">I believe you may be able to use an 99-00 Si AC bracket.</TD></TR></TABLE>
99-00 bracket will work
you can find them anywhere, for peanuts, you just have to look
I have found them for as little as $30 each
ErikV
Jun 9, 2005 08:20 AM
roc
Sep 13, 2004 05:14 PM
