H22-EG more Knock sensor fun
Old Jun 21, 2004 | 09:47 AM
SleeprCivic's Avatar
Default H22-EG more Knock sensor fun
I have the CEL -23 and I just want some other's feedback on this.
I do not have shielded wire, but from reading all the posts, I will do this soon.
I have a 2 wire knock sensor. What are these from? I grounded the GRN wire from it to sensor ground and the other to D3.
MY QUESTION IS... When does the CEL usually come on for people with KS problems? I drive mine for 5-10 minutes and it usually comes on after the engine is warmed up. Would this indicate what the problem is? I"m going to shield the wire and then if I still get a code, I'm going to get a 1 wire KS.
Old Jun 21, 2004 | 11:14 AM
Turbogixxer's Avatar
Default Re: H22-EG more Knock sensor fun (SleeprCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeprCivic &raquo;</TD></TR><TR><TD CLASS="quote">MY QUESTION IS... When does the CEL usually come on for people with KS problems? I drive mine for 5-10 minutes and it usually comes on after the engine is warmed up. Would this indicate what the problem is? I"m going to shield the wire and then if I still get a code, I'm going to get a 1 wire KS.</TD></TR></TABLE>
No, the KS code does not come on until you drive it for a bit. You problaby have:
1) bad wiring (sheilded that wire, y0)
2) bad sensor
italian_virus
Oct 13, 2010 08:28 AM
JBirch_97Prelude
May 27, 2007 01:03 PM
sir2sol
May 12, 2007 05:32 AM
djpepsi
Aug 17, 2006 09:35 AM
