what's needed for teg front brake upgrade?
I'm gonna be throwing in some 90-93 integra knuckles in my CRX...DO I need the control arm, tie rods and every other thing? I'm guessing I just need the knuckle, from upper ball joint down to lower ball joint right?
I don't know this for a fact, but I believe I remember hearing that you'll need the outer tierod end from the teg to make it work. You should be able to use the stock control arms however.
[Modified by solorexer, 12:29 PM 11/16/2001]
the 90-93 tegs use a taller knuckle than the Civ/CRX uses.
This will upset the camber curve and make for some funky handling.
You are best off to get either 90-91 EX brakes or kit from Brian at Fastbrakes.com.
I just bought a pair of front knuckles off of a 91 SI HB for 120 bucks...sound good? I thought it sounded great.
Also got the harness for 50 bucks off of the same car.
commotion
Mar 2, 2009 01:23 AM
rice4life
15
Aug 12, 2002 10:39 PM
customx_
Jan 14, 2002 04:54 AM
