Need helm scan ASAP
Old Jun 21, 2004 | 08:33 AM
IntegraXSi's Avatar
Default Need helm scan ASAP
Ok heres the deal I'm trying to sell my civic I took out my Cd player I had in there to put in my new ride, well I had an Old kenwood lying around that I'm seelling with the car. Cut the car on nothing and the clock was barly on and read 1:00 so I keep the car on a few min checking my wireing cut it off then back on the clock went back to 1:00 I knew then it was the 12v constant blue/white traced it back to the harness above the Fuse block and the termnal is dead. So I need a scan of the Dash harness and behind the fuse block to I can try to find the short.. Or a new spot I can move the wire to thats a 12v constant..
Old Jun 21, 2004 | 09:01 AM
976's Avatar
976
New User
Default Re: Need helm scan ASAP (IntegraXSi)
Do you have a multi-meter on hand?
Old Jun 21, 2004 | 09:06 AM
IntegraXSi's Avatar
Yes!
Old Jun 21, 2004 | 09:13 AM
976's Avatar
976
New User
Default Re: (IntegraXSi)
Can you test the wire? What's the read out? If not find the closest power source wire with the multi-meter. I hope that helps... I've been trying to find the wiring diagram, so far unlucky.
Old Jun 21, 2004 | 11:08 AM
IntegraXSi's Avatar
No havent tested the wire yet (well used a test light crap) and there was a very weak light then nothing so... HELP
ME GUYS THANKS
Old Jun 21, 2004 | 11:11 AM
976's Avatar
976
New User
Tap the 12v power wire from ECU and put it thur the firewall, then try...
95hondaacc
Feb 11, 2009 06:42 PM
dafuzzbudd
Audio / Security / Video
Nov 14, 2008 08:00 AM
sz9182
Apr 30, 2007 08:27 PM
staticrex
Dec 8, 2004 11:46 AM
Doh!
Feb 14, 2004 07:40 AM
