vehicle speed sensor question
Old Jun 21, 2004 | 08:28 AM
Prod's Avatar
Default vehicle speed sensor question
I need a vehicle speed sensor for a 90 b18a block...will any vss work from any b-series or do I need a specific one ?
Thanks !
Old Jun 23, 2004 | 07:42 AM
Prod's Avatar
Default Re: vehicle speed sensor question (Prod)
anybody know ?
Old Jun 24, 2004 | 06:16 PM
chrisnova's Avatar
Is the wheel speed sensor for input into the ECU of the anti lock brake system? If so I would pic one up in the junk yard. That kind of part might be difficult to find at the local auto parts dealer I would think, although not sure. Good luck!
Old Jun 24, 2004 | 08:35 PM
carcala's Avatar
im pretty sure any will work. even from a sohc. could be wrong. wait for someone else to response.
Old Jun 26, 2004 | 06:43 PM
KLeSe's Avatar
Default Re: vehicle speed sensor question (carcala)
They are actually different throughout the years. Be sure to take yours out to match it at the junkyard. They have slightly different bolt patterns. Good luck.
Old Jun 26, 2004 | 07:36 PM
ljoe's Avatar
you'll need one from a cable b-series tranny, i'm not sure about any sohc trannys though. 88-91 jdm tranny or 90-93 teg tranny will do fine, later model b16s and integras use an electronic vss, not a speedometer cable setup, so that won't work for you.
*edit* what car is this going into? that will determine what you need
Old Jun 27, 2004 | 02:02 PM
Prod's Avatar
Default Re: vehicle speed sensor question (ljoe)
needs to go in a 2000 teg...I guess I'll just try to match them up then, thanks
Old Jun 27, 2004 | 08:31 PM
ljoe's Avatar
alright then, you'll need the electronic one, but i'm sure you figured that out
550whpcivic
Transmission & Drivetrain
Jul 12, 2010 10:14 PM
worx
Oct 16, 2009 07:40 PM
chulopilong
Dec 31, 2004 12:26 PM
kim_2_da_chee
11
Oct 8, 2003 09:02 AM
bumpin_bass
Sep 6, 2003 01:12 AM
