Front vs Rear Track Tire Wear
Old Jun 21, 2004 | 07:52 AM
nsxtasy's Avatar
H-T Order of Merit
Default Front vs Rear Track Tire Wear
I was just wondering how much longer track tires wear on the ITR rear vs the front when used on the racetrack - twice as long? Three times as long? Five times as long?
I've been rotating my track tires, always using the ones with more tread on the front, so they wear evenly, as a set. So as a result, I have no idea how much longer the rears last.
TIA...
Old Jun 21, 2004 | 08:18 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
I've been running staggered tires so I can't rotate them front to back. Based on my experience, the rear lasts about 3 times as long as the front.
Old Jun 21, 2004 | 11:55 AM
Big Phat R's Avatar
Default Re: Front vs Rear Track Tire Wear (nsxtasy)
I find it depends on the track surface and layout, alignment, tire compound, tire pressures, ambient temperatures and driving style.
On some tracks I get even tire wear - others wear the fronts like mad.
Rotating tires is best to even out things - that's what I do - but its not perfect.
I would agree with Wai's estimate esp considering he's running a wider front tire.
Old Jul 10, 2005 | 09:46 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: Front vs Rear Track Tire Wear (Big Phat R)
what is a staggered tires?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
TIA...
Old Jul 10, 2005 | 09:49 PM
migs's Avatar
Default Re: Front vs Rear Track Tire Wear (BLUE EH3)
Staggered tires is when you have 2 different size tires.
Old Jul 10, 2005 | 11:33 PM
Bbasso's Avatar
At Expo 5 I would say the front wore double as fast as the rears. But then I was doing a bunch of driftos...
RA1s= 205/50-15
Old Jul 11, 2005 | 05:12 AM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">I find it depends on the track surface and layout, alignment, tire compound, tire pressures, ambient temperatures and driving style.
I totally agree with this
I think alignment and suspension setup play the heaviest in this department.
But I mark and rotate my tires Every track day or days. The wear rate has been pretty even thus far with the rears usually just picking up loads of rubber at the end of hot sessions.
Also, on tracks Like Limerock where it is predominantly right turns mixed with crazy compression, I can even get more wear on my drivers side alone.
Between all of us though we're probably talking about several different compounds, setups and driving styles/experience.
Modified by 1GreyTeg at 9:24 AM 7/11/2005
ewaugh
Apr 29, 2005 08:16 AM
nsxtasy
19
May 22, 2003 09:14 AM
canuckr
38
Sep 14, 2002 10:45 PM
Petah
Feb 18, 2002 11:42 AM
Ibuprofen
Jul 26, 2001 07:35 PM
