D15b over heating need help
Old Jun 20, 2004 | 11:41 PM
NewBorn_EG's Avatar
Default D15b over heating need help
ok im about to change the thermostat ..hoping that will be all if not what else could it be.
my friend has the same motor and uits doing the samething and he change the thermostatt,radiator hoses..nexts he going to change the head gaskett and radiator..
Old Jun 21, 2004 | 04:27 AM
ErikV's Avatar
Default Re: D15b over heating need help (jdmEFnine1)
Your radiator hoses could be affected by the excess heat, so replace them as well. I would do that for sure. Costs almost nothing, but can save you a lot of trouble.
Is your waterpump still ok?
Old Jun 21, 2004 | 05:20 AM
JimmyAtlantis's Avatar
Default Re: D15b over heating need help (ErikV)
Do you have an air pocket in your cooling system? Try bleeding the system.
Old Jun 21, 2004 | 08:16 AM
NewBorn_EG's Avatar
havent checked the water pump yet but thats on my to do list
Old Jun 21, 2004 | 08:17 AM
NewBorn_EG's Avatar
Default Re: D15b over heating need help (JRI94)
there mint be a pocket ..how do i go about bleeding the system..im new to eg.had a ef before .so im still learning on the eg
Old Jun 21, 2004 | 08:34 AM
owen_the_soyboy's Avatar
you should use a Honda thermostat.
autozone/pepboys = junk.
does your radiator fan come on when the motor is running hot? it should....
Old Jun 21, 2004 | 09:09 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmEFnine1 &raquo;</TD></TR><TR><TD CLASS="quote">there mint be a pocket ..how do i go about bleeding the system..im new to eg.had a ef before .so im still learning on the eg</TD></TR></TABLE>
Let your car warm up until the fan kicks on. The hose from the top of the radiator...follow it to the block and there should be a bleed valve right there. I think it's an 8mm nut. When fluid comes out, close it up.
Old Jun 21, 2004 | 12:21 PM
NewBorn_EG's Avatar
Default Re: D15b over heating need help (owen_the_soyboy)
yeah the fan comes on
Old Jun 21, 2004 | 12:22 PM
NewBorn_EG's Avatar
cool i'll look at it once i get it back from paint ..at the end of the month
sierrarafa
Aug 17, 2013 06:16 AM
-Championship-
Nov 26, 2006 07:14 PM
missionaryrider
Jun 21, 2005 09:19 PM
Steemo
Jun 17, 2005 03:19 AM
Specialk
May 22, 2003 08:59 AM
