Front Right Wheels SHAKES When Accelerating Or While Turning Left!!!
Old Jun 20, 2004 | 10:34 PM
92accordjdmh22a's Avatar
Default Front Right Wheels SHAKES When Accelerating Or While Turning Left!!!
Yes, this is very annoying, i had this problem for awhile, ever since i put the h22a in my 92 accord it shakes violently. When i turn left or going on a high rate of speeds i can feel the front right vibrating. Could this be cause i need a alignment or camber kit, i just want to know the main cause so i can fix it first. If this help you find the problem, i did a auto to five speed conv. But when i turn right it doesnt shake at all. Sometimes when im just driving straight and it starts to shakes, i push the gas and it goes away until i let go of the gas. please help....
Old Jun 20, 2004 | 10:53 PM
Accord94DX's Avatar
Default Re: Front Right Wheels SHAKES When Accelerating Or While Turning Left!!! (92accordjdmh22a)
possible inside CV joint problem.
take the axle out and see if there is play in the joint. When you rotate the joint with your hand while holding the shaft there should not be movement. If there is, it is junk.
Old Jun 21, 2004 | 08:55 AM
DragonTLS's Avatar
check your engine mounts
vickpick
Honda Civic (2001 - 2005)
Mar 14, 2011 03:35 PM
redDAinteg
Feb 17, 2007 07:56 PM
Hazzo
Jan 24, 2005 09:57 AM
TSIntegra
Jun 5, 2003 11:25 AM
One Bad GeeSeeR
Nov 3, 2002 11:28 PM
