Upper Radiator Hose Diameter--2000 Civic EX
Old Jun 20, 2004 | 09:31 PM
Sohc Driver's Avatar
Default Upper Radiator Hose Diameter--2000 Civic EX/B18b hybrid
Hey whats up guys, I am investing in a Greddy Water Temp Sensor Adapter..but wasn't sure which to order. They come in 30mm, 34mm, and 36mm. Do you guys have any ideas as to which one I should order? 2000 Civic EX/B18b Hybrid
Thanks,
Khoi
Modified by Sohc Driver at 12:42 AM 6/21/2004
Modified by Sohc Driver at 12:44 AM 6/21/2004
Old Jun 21, 2004 | 06:09 AM
Default Re: Upper Radiator Hose Diameter--2000 Civic EX/B18b hybrid (Sohc Driver)
Bump Yo
Old Jun 21, 2004 | 06:36 AM
Honda Hick's Avatar
Just go outside with a tape measurer and measure your rad hose.
Old Jun 21, 2004 | 10:19 AM
Default Re: Upper Radiator Hose Diameter--2000 Civic EX/B18b hybrid (Honda Hick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Hick &raquo;</TD></TR><TR><TD CLASS="quote">Just go outside with a tape measurer and measure your rad hose.</TD></TR></TABLE>
Because I prefer not to unhook it and let the coolant run out...it would be a lot simpler if someone just has one laying around.
Khoi
Old Jun 21, 2004 | 10:24 AM
DaX's Avatar
DaX
Loved
Community Favorite
I know on my civic with a swap [B18] I'm using a B18A radiator hose. I'm doing a sidewinder, so my upper radiator hose is going to be a bitch. Anyhow...the ID of the B18A upper rad hose is 1.25", which comes out to about 31.75mm.
Old Jun 21, 2004 | 10:35 AM
Default Re: (DaX)
awesome..Thanks Dax..but I guess if i ordered a 30mm OD adapter..i would just have to clamp the hose tight around the adapter..
This is for my greddy water temp sensor BTW
Khoi
Old Jun 21, 2004 | 11:51 AM
B18EG6's Avatar
Default Re: (Sohc Driver)
Does it matter where you put the sender for the water temp? Im a bit hungover right now... which way does the water flow? pump to thermostat or thermostat to pump?
Old Jun 21, 2004 | 02:58 PM
DaX's Avatar
DaX
Loved
Community Favorite
Pump -&gt; Thermostat -&gt; Top of Radiator -&gt; Bottom of Radiator -&gt; Engine Coolant Passages -&gt; Pump
hybridevul
Jun 16, 2005 07:03 AM
mingbling96
Jun 1, 2005 08:19 PM
wannakno
Acura TL, RL & ZDX
Sep 15, 2004 06:48 PM
Sohc Driver
Jun 21, 2004 10:20 AM
B18EG6
May 5, 2003 11:36 PM
