b16 problems
Old Jun 20, 2004 | 09:12 PM
chattownrexer's Avatar
Default b16 problems
ok it ran and then it died its in a 91 rex and we think its the distributor but were not sure... i also had a remote start on it before the swap could the starter kill in the alarm have anything to do with it? let me know thanks....
Old Jun 20, 2004 | 09:14 PM
EL Vap133's Avatar
Default Re: b16 problems (chattownrexer)
If you think it's the dist, have you checked to see if the rotor is on? Maybe it fell off?
Old Jun 20, 2004 | 10:19 PM
hahagasdcrx's Avatar
Default Re: b16 problems (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">If you think it's the dist, have you checked to see if the rotor is on? Maybe it fell off? </TD></TR></TABLE>
that happened to me a few times and just recently a bad main relay. Main relay can cause it from cranking over.
Old Jun 21, 2004 | 09:33 PM
Default Re: b16 problems (hahagasdcrx)
hey guys thanks i got it to run the guy pressure washed the engine bay and it nocked a ground loose.... got it fixed now heres the other problem.... when im drivin just low rpms and everything it just pops outta gear... is my clutch slippin? i know it sounds dumb, i just got into to cars and whatnot so could you let me know, like i said it just pops out....
EFdood831
Sep 24, 2007 08:40 PM
gsober
16
Dec 28, 2006 07:41 AM
hybridhatch07
Aug 6, 2006 04:01 PM
HONDA_CIVIC_HATCH_Boy
Feb 27, 2006 06:17 PM
teler86
Jan 14, 2005 10:57 AM
