'bitch pin' question... steel band instead
Old Jun 20, 2004 | 05:13 PM
B18EG6's Avatar
Default 'bitch pin' question... steel band instead
hey-
how do I get this off? I thought one of those pins is supposed to be there, guess this is the first time ive looked at it since i got the motor
and should I replace this band with a bitch pin once i get the band off?
Old Jun 20, 2004 | 05:15 PM
GSRrR's Avatar
Default Re: 'bitch pin' question... steel band instead (B18EG6)
its like a "C" just take it off and the pin is in there.
you can reuse this clip. get a new pin.
Old Jun 20, 2004 | 05:49 PM
B18EG6's Avatar
Default Re: 'bitch pin' question... steel band instead (GSRrR)
thanks! simple, and to the point!
thanks again... ill hit up honda tomorrow.. how much is this pin?
Old Jun 21, 2004 | 07:45 AM
J-Brooks's Avatar
I always used the same pin. I didn't know you had to get a new one.,
Old Jun 21, 2004 | 08:06 AM
95 integra's Avatar
Default Re: 'bitch pin' question... steel band instead (J-Brooks)
why are you taking it out? Ive found it much easier just to drop the linkage with the tranny.
Old Jun 21, 2004 | 09:00 AM
LostAndFound's Avatar
I think I paid $3 for the pin. Cheap. But you most likely are going to have to have tem order it.
Old Jun 21, 2004 | 11:22 AM
B18EG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">why are you taking it out? Ive found it much easier just to drop the linkage with the tranny.</TD></TR></TABLE>
Eh Im pulling the whole motor.. just thought it would be a lil easier to take it out now... i guess i could leave the tranny in the car and just pull the longblock? How hard would that be? Im using crappy hand tools and mayyyyybe a compressor with an impact wrench.
Old Jun 21, 2004 | 11:48 AM
95 integra's Avatar
If I was pulling the motor I would drop the entire engine/tranny because its going to be a pain trying to get the motor seperated from the tranny without taking the tranny out first. I mean, the tranny is pretty easy because you can just get somebody under the car and drop it on them and then slide it out(and reverse for install) but the tranny only weighs about 100lbs whereas the motor/head weighs alot more. If you drop it out the bottom side(which ive done....seems easier then the top side, atleast with the lower motor mounts still attached to the motor) then you could still leave on the shift linkage, but Id probably just go ahead and take it off.
foolsforever
Aug 20, 2018 08:52 PM
slayerfromhell212
Feb 25, 2008 10:23 PM
B serious
Honda S2000
Sep 24, 2007 09:57 PM
B16CRXT
Mar 10, 2007 08:58 PM
I CRX I
22
Jan 17, 2007 10:22 AM
