problems with check engine light
Old Jun 20, 2004 | 05:06 PM
darkdemon215's Avatar
Default problems with check engine light
codes come up knock sensor, idle air control and throttle position sensor
93 civic hatchback with 94 gsr engine using wiring from civic
help
Old Jun 20, 2004 | 05:08 PM
Turbogixxer's Avatar
Default Re: problems with check engine light (darkdemon215)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkdemon215 &raquo;</TD></TR><TR><TD CLASS="quote">codes come up knock sensor, idle air control and throttle position sensor
help</TD></TR></TABLE>
You have the knock wired up? What color wires does the IACV have going to it? Does the car run/idle at all?
Old Jun 20, 2004 | 05:12 PM
car idles fine except when i hold the gas alittle and it goes up and down slightly
but runs good at low rpm but at high it sucks runs slow
Jordan Sharples
Honda Civic (2001 - 2005)
Jul 7, 2018 10:38 PM
Civic082382
Oct 23, 2010 05:41 PM
EJeff8
May 3, 2010 05:07 AM
Madspeed
Mar 20, 2005 06:38 PM
H23 Power
Apr 21, 2002 10:39 AM
