speedometer only works in reverse....
Old Jun 20, 2004 | 02:18 PM
ludeDVR's Avatar
Default speedometer only works in reverse....
Just finished up my clutch install and i went through 2 VSS brackets...but anyways
My speedometer and odomotor don't work, i know the odomotor works with the speedometer. The weird part is, if i go in reverse, the speedometer and odomotor both work....the VSS plug is getting the correct voltage, but i didn't think the odometer moved when going in reverse? Do all hondas do that?
Any ideas why my speedometer doesn't work when i go forward and i get a VSS code?
i've heard that maybe my speed gear is damaged and that is connected to the diff....would a new quaife solve that or is the speed gear something totally different?
weird part is...when i first took it out for a test drive, i went around the block and then came back to my house and turned off the car. Speedo and odometer worked fine for .4 miles. Then as soon as i came back out and started up the car to leave...the speedo was dead
If the VSS was bad...would it still show the speedo going up and odometer going up in reverse?
Old Jun 21, 2004 | 10:23 AM
ludeDVR's Avatar
bumpity bump
ludeDVR
Jan 29, 2020 06:10 AM
H22 EG Dude
Nov 14, 2010 12:41 PM
mr. biggles
Apr 11, 2007 06:59 AM
rawkus
Sep 5, 2006 06:24 PM
WuWarrior
Jan 28, 2003 11:55 AM
