Which plugs with MSD ignition?
my buddy has a b18b in his delsol..its got a full msd igntion and plug wires and I was wonderin what kinda plugs are the best for that set-up? I sold him some NGK laser platinums cuz I thought theyd be the best for that igniton, what do u guys reccomend?
I recomend buying one of each brand. Then put one in each cyln. For example have some NGK's in the 1 cyln. and some Bosh in the 2 cyln. and so on. After that go out and drive hard and tell us what cyln. is running the best. That would be the plug you should use.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boricua8503 »</TD></TR><TR><TD CLASS="quote">I recomend buying one of each brand. Then put one in each cyln. For example have some NGK's in the 1 cyln. and some Bosh in the 2 cyln. and so on. After that go out and drive hard and tell us what cyln. is running the best. That would be the plug you should use.</TD></TR></TABLE>
that was almost a good idea
I'd stick with NGK R's
civicEXtreme
14
Jan 27, 2006 09:35 PM
