help me with my mounts!!!!!
Old Jun 20, 2004 | 02:02 PM
handa's Avatar
Default help me with my mounts!!!!!
i have a b16a gen2 and i'm using 95 gsr mounts/brackets on it:
I've used #2, #4, and #5. #3 i used off my stock z6. BUT i can't seem to use #1 for some reason. I believe it is the driver side lower torque mount.
Any ideas? Please help me. My motor shakes like a bull in an arena right now.
Old Jun 20, 2004 | 04:02 PM
dirtyturtle's Avatar
Default Re: help me with my mounts!!!!! (handa)
yes thats correct... 1, bolts to the front of the block.
Old Jun 20, 2004 | 04:40 PM
handa's Avatar
Default Re: help me with my mounts!!!!! (JDMPROject)
#1 does not fit my b16
Old Jun 20, 2004 | 04:53 PM
Turbogixxer's Avatar
That help?
Old Jun 20, 2004 | 04:56 PM
handa's Avatar
Default Re: help me with my mounts!!!!! (turbogixxer)
LEFT FRONT MOUNT: Make sure to get the AC mount, which bolts to the frontside of the block.
AC mount from my 95 GSR or my stock z6?
Old Jun 20, 2004 | 05:04 PM
If you want to retain A/c, you will have to get a del sol DOHC VTEC (p54)(94-95) a/c bracket. It bolts to B-series blocks and uses a SOHC compressor. You can use the integra mount if you do not want a/c.
Old Jun 20, 2004 | 06:00 PM
eg_type_r93's Avatar
any b series front lower mount will work the d series wont work cause of the different block sizes
Jadwin
Jun 9, 2014 11:19 AM
tegdude227
May 27, 2009 01:48 PM
JAPCIVIC R
Jan 19, 2004 10:20 PM
CircuitFG
Jul 21, 2003 08:08 AM
boywonda
May 31, 2003 08:40 AM
