Eagle rods: Honda or ACL bearings
I'm building my B20VTEC and I'm using the Eagle H beams. Which bearings should I use for this? I have head great things about both Honda OEM's and ACL's. I was going to use Honda OEM's for the main's just for the fact that the bores may be a little different in each one and I want to get an exact clearence number for each one where as the rods are all machined to the same spec. Any advice is appreciated.
we sell alot of Eagle rods here and we have used honda bearings and ACL bearings, they both seem to work really good. It is also important on who is puttung the bearings in also. We have ACL bearings in some all motor cars that make over 200 whp
I used Clevite bearings on my old setup.
Question though. Did you cut the crank at all? If you did, you won't be able to use Honda bearings. They don't make undersized bearings. Well, "oversized" if you're putting it on the rod, if ya know what I mean.
