Vibration problem???
could be sparkplugs,,,not so sure but don't worry that happens to every cars just slightly press your gas to raise the rpm a lil bit and it will be fine
Check your motor mounts, what rpm does your car idle @? Sometimes an idle too low will cause the car to gasp and shudder. There's a plate with two screws near your throttle body which holds your throttle cable in place, loosen those screws just enough to tap the plate and slide it toward the driver side to raise the idle, passenger to lower it. ~800 - ~1000rpms is usually best. Hope that helps you, - Darrell
