ebay strut & tie bar set
Old Jun 20, 2004 | 10:34 AM
ecsahs3's Avatar
Default ebay strut & tie bar set
So, my buddy and I installed the ebay crx strut and tie set I bought for $80. It came with the upper & lower front and upper & lower rear. We installed all but the upper rear. The install wasn't that fun, being that the mounting points interfeared with some brackets & rear sway bar. The rear lower tie bar bolts touch the sway bar. It was a tight fit and a **** to install. I'm gonna have to get rid of it when I upgrade the rear sway though. But, all in all, the car is stiffer around corners and it the improvements are noticable. Good $80 spend.
Also, got the car running smooth again. I just replaced the cap and rotor a few months ago but then the car kept dying. Tried fooling around with the timing and so forth but couldn't figure it out. So yesterday, we bought a new cap and rotor and now it runs like a champ again. The car runs good for having 240k miles. It was a good day.
Old Jul 2, 2004 | 03:22 PM
STN_Pat's Avatar
will the tie bar fit any good front and back is i dont have no sway bars ?
Old Jul 7, 2004 | 11:08 PM
ecsahs3's Avatar
Default Re: (STN_Pat)
if i understood you right, the tie bar doesn't attach to the sway. so, if you don't have a sway bar, the tie bar will still bolt up. do you at least have the origional sways?
BWFL
Sep 24, 2010 05:11 AM
redlinexd
Suspension & Brakes
Jun 20, 2010 01:49 PM
wushubrian
39
Apr 8, 2006 10:11 PM
njandrewg
Feb 27, 2005 05:11 PM
