Valve Adjustment question
Old Jun 20, 2004 | 09:04 AM
Chubz's Avatar
Default Valve Adjustment question
the only question I have is that, do you adlust each cylinder according to the firing order as in 1.3.4.2 and making sure that each of them are at TDC according to the 1.3.4.2 order
Old Jun 20, 2004 | 09:14 AM
uNF$@#!'s Avatar
Default Re: Valve Adjustment question (Jelly Bean)
yesh...actually, you can adjust them in any order you like. most people just follow the firing order because its easiest.
helms manuals rox....even the e-helms
now getting the tolerances down....thats a pain in the ***.
Old Jun 20, 2004 | 02:51 PM
mikehonda's Avatar
Default Re: Valve Adjustment question (Captain Commando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Captain Commando &raquo;</TD></TR><TR><TD CLASS="quote">yesh...actually, you can adjust them in any order you like. most people just follow the firing order because its easiest.
now getting the tolerances down....thats a pain in the ***.</TD></TR></TABLE>
Ya, what he said. Also, for best results adjust at 100 degrees or cooler.
Old Jun 20, 2004 | 03:27 PM
TypeRPaul's Avatar
Helms will save your life...I would highly recommend it!!!!!!
Old Jun 20, 2004 | 03:28 PM
Chubz's Avatar
Default Re: (TypeRPaul)
just downloaded it, thx fellas
Old Mar 24, 2005 | 12:57 AM
JDM97dc2R's Avatar
Default Re: (Chubzilla)
where can i download the helms manual?
Old Mar 24, 2005 | 01:01 AM
jiahanhao's Avatar
Default Re: (JDM97dc2R)
seriously... hahah
Old Mar 24, 2005 | 05:12 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM97dc2R &raquo;</TD></TR><TR><TD CLASS="quote">where can i download the helms manual?</TD></TR></TABLE>
Yeah, wait, what? Spill the beans Soup ****?
Old Mar 24, 2005 | 05:36 AM
ITR184's Avatar
Default Re: Valve Adjustment question (Chubzilla)
What I do is use a remote starter button that I made out of two leads and an old ford starter button. disconnect the distributor, and battery put the two leads on the starter solenoid then connect the battery back up. I do one cylinder at a time. Watch the lobes on the cams and when the rocker arms are on the back of the lobes I adjust that set of valves.
Old Mar 24, 2005 | 06:20 AM
kay_animation's Avatar
What that guy said...
Old Mar 24, 2005 | 06:33 AM
MattD@Stoptech's Avatar
Default Re: Valve Adjustment question (Cod Sac)
too lazy to turn the engine by hand?
Old Mar 24, 2005 | 08:20 AM
B2FiNiTY's Avatar
Default Re: Valve Adjustment question (El Pollo Diablo)
If you still have the PS, use that pully
Old Mar 24, 2005 | 08:30 AM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">too lazy to turn the engine by hand?</TD></TR></TABLE>
even easier... Put the car in 4th gear while ona flat surface then roll it in gear til the marks are where you want
Old Mar 24, 2005 | 09:01 AM
ITR184's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">too lazy to turn the engine by hand?</TD></TR></TABLE> Actually I started using the remote starter button about 15 years ago on high compression V-8's, and was to lazy to pull the plugs. Some of the V-8's I have had, I put solid lift roller cams in. I had to adjust valves about every tank or two of gas. And you have to pay more attention, because you can't see the cam. You have to adjust the exhaust valve as soon as the intake valve closes, and adjust the intake as soon as the exhaust begins to open.
sometimes when you adjust multiple cylinders you might have a rocker arm resting on the side of the cam lobe. Thats why I do one cylinder at a time. I might have to spin the cams a couple more times, but it ain't no sweat off of my nuts.
Old Mar 24, 2005 | 07:23 PM
MOVE OVER's Avatar
i have the helms manual u can download. its not hosted, so AOL IM would be the best. send me ur AOL IM SN in an IM here, and when i log on i will look for ya
b20vtect4turbo
Old Mar 24, 2005 | 08:08 PM
warwagon's Avatar
Default Re: Valve Adjustment question (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">If you still have the PS, use that pully </TD></TR></TABLE>
good idea **** finity
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 255.255.255.255 &raquo;</TD></TR><TR><TD CLASS="quote">
unless you get the snapp on tool that has the socket/screwdriver combo
vtec.dc2
Nov 29, 2006 01:58 AM
1JDMDOMINICAN
Apr 15, 2006 05:32 AM
user 018229
Aug 9, 2004 08:32 PM
DC2NING
Jun 3, 2003 08:50 PM
Volcom
Jan 21, 2002 07:01 PM
