b-series turbo cams
Hi,
i'am also interested in this...
i know that there is a lots off stuff around (i searched allready) but everything i know is that some people swar of the cam x and others of the cam y ... but noone say why he think that the cam is so much better the another or the stock cams.
and another thing i never found is how much difference this cam makes against the stock b16 cam?
i don't want to spent 500-800 $ for a set of cams just to get 20hp more!
Hope you can help.
Thanks
Malte.
Hope you can help.
Thanks
Malte.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snailpoweredEK »</TD></TR><TR><TD CLASS="quote">then just use gsr cams. </TD></TR></TABLE>
Yes, but WHY?
Yes, but WHY?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by calvinPGMFI »</TD></TR><TR><TD CLASS="quote">Brian for Hondaswap told me why put diff cams for 15 hp whne u up your boost with 1 psi give u 20 hp?
So i think i will old my stock cams</TD></TR></TABLE>
Thats exactly what i think too...
and this is the reason why i want to know why a specific cam is so much better then the stock b16 cam and how much power i can get with other cams.
a far as i know for a turbo engine it is better to have a cam that has less valve overlap and longer valve opening time to get more air/fuel mixture in the cylinder.
but you can nowhere read data on cams like this to determine whats the best cam.
Greets
Malte.
Greets
Malte.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OldGSR »</TD></TR><TR><TD CLASS="quote">What cams would you recommend for a boosted (8-10psi) b-series vtec?</TD></TR></TABLE>
a few more lbs of boost
