B20/VTEC swap....VTEC not kicking in.....
Old Jun 20, 2004 | 06:43 AM
shiftgear8000's Avatar
Default B20/VTEC swap....VTEC not kicking in.....
Ok, well here's the stats....I have a 95 civic ex. I swapped in a B20 block with a GS-R head and tranny. I'm using the D16z6 wiring harness and ECU (hasn't been chipped yet). So I took the car for it's first ride the other day and when I expected to hit VTEC....nothing. Any reason that it isn't kicking in? I ran the oil line from the block to the head and hooked up the D-series VTEC solenoid tot he GS-R head and plugged it in. Any help would be great...thanks.
-jase
Old Jun 20, 2004 | 07:27 AM
JDMFreak's Avatar
Default Re: B20/VTEC swap....VTEC not kicking in..... (shiftgear8000)
check your vtec solenoid make sure everything is correctly hook-up im not sure if a d-series vtec solenoid will work if so new infor me... but my friend had the same problem on his b16a crx and we could not figure out what happen until he change his oil...and he found out that he didnt have enough oil in his car...so i would check your oil if it not correct vtec will not work
Old Jun 20, 2004 | 11:02 AM
powerofdreams8's Avatar
Default Re: B20/VTEC swap....VTEC not kicking in..... (JDMFreak)
Did you plug the VTEC oil supply hole in the bottom of the head (on the mating surface of block to head)?
Old Jun 21, 2004 | 01:38 AM
sleeperEG114's Avatar
Default Re: B20/VTEC swap....VTEC not kicking in..... (powerofdreams8)
i think u need a gsr vtec solenoid ... depending on if its a obd1 or obd2
Old Jun 23, 2004 | 10:03 AM
Yes....the hold on the underside of the head was plugged. I'm running an OBD1 ecu and I have the factory D-sereies VTEC solenoid.
Old Jun 27, 2004 | 09:50 AM
djickabod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shiftgear8000 &raquo;</TD></TR><TR><TD CLASS="quote"> I'm using the D16z6 wiring harness and ECU (hasn't been chipped yet).</TD></TR></TABLE>
That is your problem. You are using a P28 ecu right? Well the P28 is for a SOHC vtec. so the Vtec wont kick in right. Get it chipped for DOHC
Old Jun 27, 2004 | 12:04 PM
Default Re: B20/VTEC swap....VTEC not kicking in..... (djickabod)
you need a gsr sylenoid....u cant run on a d-series sylenoid when ur motor is a b-series
Old Jun 27, 2004 | 06:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djickabod &raquo;</TD></TR><TR><TD CLASS="quote">That is your problem. You are using a P28 ecu right? Well the P28 is for a SOHC vtec. so the Vtec wont kick in right. Get it chipped for DOHC</TD></TR></TABLE>
You're a ******* moron.
Old Jun 28, 2004 | 01:16 AM
lol its okay were not all right
typeR4u
Feb 20, 2015 06:43 AM
teamvirus
Jun 18, 2008 12:58 PM
tvrsir
Jul 15, 2004 06:53 AM
FMIDRC Racer
Dec 20, 2003 07:28 AM
EkREV
Oct 7, 2001 09:37 AM
