offset rubbing issues for 15" rims
Old Jun 20, 2004 | 03:57 AM
jeremy.'s Avatar
Default offset rubbing issues for 15" rims
will a 7.5" rim with a 40 offset be an issue at all? does the offset of the rim affect the appereance at all or just makes the wheel stick in or out farther right? reason is i'm about to my tarmacs but i don't know what offset to go with. i want to get 16's but the spokes don't curve out as much as 15's...thanks
Old Jun 20, 2004 | 05:34 AM
SleepnCiViC's Avatar
i got 6.5 w/ 40mm offset and it rubs ver occasionally, so id guess youd have some rubbing for sure
Old Jun 20, 2004 | 08:28 AM
Black R's Avatar
25 Year Member
Default Re: offset rubbing issues for 15" rims (ekay_jeremy)
.....what car are you asking about?
I have 15x7.5 +40 wheels on my itr and with 205/50/15's don't have much of an issue. I highly recommend 7.5-9.5 wide wheels after using them.
If you're worried about rubbing at full lock, you should also consider tire size and ride height. My car is dumped, btw
Old Jun 20, 2004 | 10:28 AM
Pondus's Avatar
Default Re: offset rubbing issues for 15" rims (Black R)
I have a set of 15x7 +38 wheels with 195/60 crappy all season Michelins and i have no issues with rubbing. My ITR is currently on stock suspension.
If it will rub is entirely dependent of what tire size you are running and how low your ITR is. ( I'm assuming you have a ITR as this is the ITR forum)
HA0LEFIED
Nov 23, 2006 12:33 AM
KRWOO79
Acura TSX
Jun 13, 2005 08:44 AM
stickyfingers
Mar 10, 2004 07:03 PM
90-CRXSi
Sep 1, 2002 01:59 PM
mattL
Jan 17, 2002 08:44 AM
