Which brake fluid are you using on your ITR?
Old Nov 15, 2001 | 04:19 PM
Sam's Avatar
Sam
Default Which brake fluid are you using on your ITR?
Please give the name & the dot # of the brake fluid you are using? Possibly, please provide the price & where can I buy it. Thanks
Please also give a comment on how u like its performance.
Old Nov 15, 2001 | 04:24 PM
Type Goch's Avatar
New User
Default Re: Which brake fluid are you using on your ITR? (Sam)
stock fluid for now. I'm gonna put in some Motul 600 as soon as i get SS lines. You can get fluid from any of the onlines distributors here on the boards.
Old Nov 15, 2001 | 04:25 PM
fast-R's Avatar
New User
Motul RBF 600, DOT 4 (I think). I buy it locally for $12 or something like that. I'm sure you can do a search on the net and find it cheaper.
[edit] Oh yeah, seems to work fine. I have SS lines, so the fade doesn't seem to be too big a problem until the later sessions. Time to change pads though, guess I'll wait till next season though.[/edit]
[Modified by fast-R, 5:28 PM 11/15/2001]
Old Nov 15, 2001 | 04:34 PM
fangtl's Avatar
Default Re: Which brake fluid are you using on your ITR? (fast-R)
I also run MOTUL, but only before track days, otherwise I use stock fluid.
Old Nov 15, 2001 | 04:43 PM
Sam's Avatar
Sam
Default Re: Which brake fluid are you using on your ITR? (fangtl)
Do we have to change the brake fluid after each event? Even if it's just a driving school?
Old Nov 15, 2001 | 04:44 PM
sackdz's Avatar
ATE Super Blue
You don't have to change it, just bleed all 4 calipers.
Old Nov 15, 2001 | 04:46 PM
yoshi234's Avatar
I shoot brides
Default Re: Which brake fluid are you using on your ITR? (sackdz)
MOTUL600
Old Nov 15, 2001 | 04:49 PM
Peter K's Avatar
New User
Default Re: Which brake fluid are you using on your ITR? (yoshi234)
Sam who is that girl in your avatar....she looks HOTTTTTTTT
Old Nov 15, 2001 | 04:51 PM
onyx00's Avatar
Super Blue here also. Just ordered (12) 1 liter cans of it
Old Nov 15, 2001 | 04:53 PM
sackdz's Avatar
Default Re: Which brake fluid are you using on your ITR? (onyx00)
12!? Damn! 1 can came with Hawk Pads F&R and SS lines in a group buy awhile back here on h-t, $180 I think.
fangtl's Avatar
Sam,
I only change it if the pedal feels mushy after an event. Otherwise I keep it in until the next event (or until it feels mushy)
Old Nov 15, 2001 | 04:59 PM
Flux's Avatar
Motul 5.1
Old Nov 15, 2001 | 05:00 PM
yoshi234's Avatar
I shoot brides
Default Re: Which brake fluid are you using on your ITR? (Flux)
Motul 5.1
5.1?
Old Nov 15, 2001 | 05:02 PM
Type Goch's Avatar
New User
yeah inlinefour-
For everyday driving, we recommend using Motul D.O.T. 5.1 brake fluid. This is an excellent brake fluid to use when upgrading your brake system with braided stainless steel brake lines, brake pads and sloted rotors. It can be mixed with SAE J 1703, D.O.T. 3, 4, and 5 synthetic brake fluid. DO NOT MIX THIS PRODUCT WITH SILICONE BRAKE FLUIDS.
Old Nov 15, 2001 | 05:08 PM
yoshi234's Avatar
I shoot brides
Default Re: Which brake fluid are you using on your ITR? (Type Goch)
Thanks James
Do you or anyone know how this is diff from 600?
-y
Flux's Avatar
5.1?
From the Motul Web site:
LONG LIFE 100% synthetic fluid for hydraulic actuated-brake and clutch systems.
DOT 5.1 NON-SILICONE BASE.
Fluidity specially designed for anti-locking brake systems.
LONG LIFE FORMULA : the high wet boiling point (185°c/365°F), superior to DOT 4 and DOT 3 fluids enables to use this product longer.
SPECIALLY DESIGNED TO ANTI-LOCKING BRAKE SYSTEM (ABS) : its viscosity (820 centipoises at -40°c / -40°F) lower than DOT 4 and DOT 3 brake fluids, allows MOTUL BRAKE FLUID DOT 5.1 an easier fluid circulation in micro-valves of anti-locking systems.
PERFECTLY NEUTRAL WITH SEALS USED IN BRAKING SYSTEMS. ANTI-CORROSION.
STANDARDS : FMVSS 116 DOT 5.1 NON SILICONE BASE & DOT 4 & DOT 3
SAE J 1703
Old Nov 15, 2001 | 05:11 PM
Type Goch's Avatar
New User
also taken from motul website
RBF 600 Factory Line
100% synthetic fluid for hydraulic-actuated brake and clutch systems. Specifically designed to resist the high temperatures of actuated (steel or carbon) racing brakes and clutch systems.
EXTREME THERMAL RESISTANCE AND STABILITY: the elevated boiling point of RBF 600 FACTORY LINE (312°c / 593°F) enables effective braking even under the extreme conditions of competition.
VERY EFFICIENT WHEN RAINY: the very high wet boiling point (216°c / 420°F), is superior to conventional brake fluids provides a particularly efficient braking system in rain and put back the apparition of vapor lock.
Old Nov 15, 2001 | 05:13 PM
yoshi234's Avatar
I shoot brides
thanks guys
yoshi - who couldn't do a search b/c he's trying to finish up some work
Old Nov 15, 2001 | 05:24 PM
Sam's Avatar
Sam
So, seems like Motul 600 is the King of brake fluid?
Anyone has experience with Valvoline Syntheic? I think it is Dot 4?
Old Nov 15, 2001 | 05:25 PM
Type Goch's Avatar
New User
usually people like to choose between either motul or ATE super blue i dont really know of other companies.
Old Nov 15, 2001 | 06:25 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
I hear (from George Knighton) that Motul makes for a mushy brake pedal. I use ATE Superblue but I'm still a young'un.
Old Nov 15, 2001 | 06:31 PM
Kengs's Avatar
Default Re: Which brake fluid are you using on your ITR? (Ross1013)
Billion Super Brake Fluid, as soon as it gets here.
Old Nov 15, 2001 | 06:52 PM
N1Spec's Avatar
New User
Default Re: Which brake fluid are you using on your ITR? (kengs)
Motul 600, awesome!!
Old Nov 15, 2001 | 06:53 PM
Cold Chunker's Avatar
I've ben running the Valvoline Synthetic for the last couple of track events as well as on the street. It works great, esp for the price. Pedal feels firm all the way. At CMP I didn't experience any fade running Hawk Blues and Valvoline - ran the same fluid for both days - even though it's cheap enough to do a full bleed for fresh stuff.
I used to run Motul because I heard it was the best and it had the highest boiling temps. Just got silly expensive after a while. Decided to try the Valvoline and see if it had "the stuff" to handle the track. What do you know! It's cheap and plenty available.
Old Nov 15, 2001 | 06:55 PM
Rboosted717's Avatar
ATS superblue here also
