$2000 what to do
tires, brake pads, coilovers, rear anti roll bar. And if theres anything left over; fuzzy dice
Or you can also get a used apexi n1 exhaust with a high flow cat [points below]
prospeed SS header - $730
Search for the following prices. google is your friend.
VAFC - $200
Cam Gears - $150
High Flow cat - $150
single fogger wet kit (i.e. 55 shot zex or NX)- $400 + 10lbs N2O @ $4/lb = $40
Dyno time (avg $150/hr) - $300
total - $1970.00
expected gains 70whp
VAFC - $200
Cam Gears - $150
total - $1970.00
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes »</TD></TR><TR><TD CLASS="quote">prospeed SS header - $730
VAFC - $200
Cam Gears - $150
total - $1970.00
expected gains 70whp</TD></TR></TABLE>
assuming that he can install all this himself....
VAFC - $200
Cam Gears - $150
total - $1970.00
I got a question. I've been searching and looking into get a direct port nitrous kit. Could I run a 100 shot with a stock block and maybe some sleeves? Taking in the account that I would be slow without the nitrous but I like to be able to control it. like going on trips or driving to and from work I'm not using any forced induction which means better gas mileage. However I know I could get a turbo and just turn the boost down, but I'm not sure I want to spend that much on a set up. Or what if I get the direct port, some cams valve springs and retainers, and some sleeves. Can I still run on stock pistons and rods.... It would be the same as running on a JRSC or a turbonetics hybrid T3/t04 on stock Psi. Let me know what you guys think
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LuDeMaZtEr850 »</TD></TR><TR><TD CLASS="quote">I got a question. I've been searching and looking into get a direct port nitrous kit. Could I run a 100 shot with a stock block and maybe some sleeves? Taking in the account that I would be slow without the nitrous but I like to be able to control it. like going on trips or driving to and from work I'm not using any forced induction which means better gas mileage. However I know I could get a turbo and just turn the boost down, but I'm not sure I want to spend that much on a set up. Or what if I get the direct port, some cams valve springs and retainers, and some sleeves. Can I still run on stock pistons and rods.... It would be the same as running on a JRSC or a turbonetics hybrid T3/t04 on stock Psi. Let me know what you guys think</TD></TR></TABLE>
no, u'll need pistons and rods with new sleeves, and more than 2 grand
i'd do some research...... and get a hooker, and hope i broke even... but thats just me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 blacksh »</TD></TR><TR><TD CLASS="quote">and when the nitrous runs out, 10whp</TD></TR></TABLE>
so refill the bottle.
b18c4door
Jul 13, 2003 07:59 PM
