H Brace/strut bar?????
I found in ebay "the H brace" which looks very interesting and was wondering if anyone new more about it. It say it bolts right up under the motor. where under the motor i dont know. I looks pretty kewl but does it do anything?
http://img78.photobucket.com/a...1.gif
its a one peice traction bar. Its similar to the z-10 or jimfab version just one peice. What it does is help eliminate wheel hop and other stuff. its good if you cant afford an LSD.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio 95 »</TD></TR><TR><TD CLASS="quote">its a one peice traction bar. Its similar to the z-10 or jimfab version just one peice. What it does is help eliminate wheel hop and other stuff. its good if you cant afford an LSD. </TD></TR></TABLE>
how can it work as a traction bar if it doesn't tie into the suspension?
hahahahahhaha
thas does not look anything like this....
that H brace is like a front lower tie bar but also bolts up 2 to more points. stiffens up the front.
hahahahahhaha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRrR »</TD></TR><TR><TD CLASS="quote">
back to the original question. Is there any benefits from this "H brace"? Also What is that gray bar and the other silver bar that connects to the gray bar.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1995 »</TD></TR><TR><TD CLASS="quote">it may just be me, but is that car is rwd?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjride1020 »</TD></TR><TR><TD CLASS="quote">there is only a few rwd tegs in the entire planet.....</TD></TR></TABLE>
O M G What did you say?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjride1020 »</TD></TR><TR><TD CLASS="quote">Thats definitely fwd just look..... there is only a few rwd tegs in the entire planet.....</TD></TR></TABLE>
hmm I would have to say there's only ONE rwd Integra on the planet.
If you use that brace, get ready for mad reduced ground clearance, as it passes UNDER the header collector.
BodyKits NW
Welding / Fabrication
Dec 27, 2007 10:00 AM
