Where does everyone....?
Old Jun 19, 2004 | 06:48 PM
Dspad_91Civic's Avatar
Default Where does everyone....?
Where does everyone run the power wire for their amp? I mean what part of the fire wall? I'm guessing you all just use a hole that is already there for wires, but which one?
Old Jun 19, 2004 | 07:59 PM
b16_madman's Avatar
Default Re: Where does everyone....? (Dspad_91Civic)
i drilled a hole for my 4 gauge, then ran it through the fresh air inlet for the main air system, then down the pass side along those clips, up the rear pass fender hump...etc.
Old Jun 19, 2004 | 08:18 PM
Full Race A6's Avatar
Default Re: Where does everyone....? (B16_madman)
Already was a massive hole right above where the ecu goes in the passenger foot well, just pull back the carpet, easiest one
Old Jun 20, 2004 | 05:21 AM
dr_latino999's Avatar
Default Re: Where does everyone....? (W O T)
If you have AC lines in your car, look down and to the left of them where they run through the firewall on the passenger side, use a good strong light and you will be able to see the grommet slightly sticking out of the wall. If you just use your fingers to search, you might / might not find it.
zsiya
Oct 4, 2011 04:03 AM
niviobjem2@aol.com
Honda Civic (2001 - 2005)
Aug 15, 2007 08:43 AM
DAVE15401
17
Jan 16, 2006 04:11 PM
577HondaPrelude
Oct 20, 2005 12:48 AM
Handle The Business
14
Aug 14, 2005 12:29 PM
