missfire in cylinder 1 and 3
ok heres my setup and problems...
96 integra GSR
Drag turbo kit
missing link
v-afc
temp 7 plugs, new wires,
after launching my car once last night i was at the drivethrough and got a cel light...at work today it was a missfire in cylinder 1 and 3. i checked the plugs...they seem ok and are less than a month old, the light will only come on at idle after a little bit....im not burning any oil either......any ideas...if i forgot some info u need just tell me and ill try to help you out...thanks in advance...
96 integra GSR
Drag turbo kit
missing link
v-afc
well ill just write the rest of the setup in case
aem fuel rail and fpr
skunk 2 cam gears
aeromotive fuel pump
full 3 " straight pipe w/ 3" hks canister
2.5 downpipe
deltagate
8 psi
turbo xs manual boost controller
skunk 2 cam gears
2.5 downpipe
deltagate
8 psi
well...my motor blew so my problems dosnt matter...now i gotta build and replace everything...i know it would happen so i didnt take it too hard... the rings went under boost
Wisdom Teeth
Mar 25, 2013 10:26 AM
screech
Apr 19, 2004 06:04 AM
asianspeed
Mar 5, 2003 08:58 PM
