Wont start, no clicking
Old Jun 19, 2004 | 02:58 PM
Usfrob22's Avatar
Default Wont start, no clicking
Hey guys I'm hopin u can help out. My buddy has a 91 LS and last night his car wouldnt start. Interior lights and radio work so I guess that rules out the main relay...
When we turn the key the starter wont even click so I guess its just not getting power. I'm thinking that its the ingition but just thought I'd ask you guys for some 2nd opinions and any other ideas on what we could check...tia
Old Jun 19, 2004 | 03:02 PM
Sack Master's Avatar
Default Re: Wont start, no clicking (Usfrob22)
Hot wire the starter to see if that works. I would say there is a better chance of it being the starter soleniod then the ignition switch.
Old Jun 19, 2004 | 03:05 PM
Usfrob22's Avatar
Default Re: Wont start, no clicking (Sack Master)
Forgot to mention we took the starter off and I took it to work (advance auto parts) and I bench tested it...It spun like it was new.
Old Jun 19, 2004 | 04:09 PM
Cjsls's Avatar
eh, i get this problem every now and then, i still don't know why because its a brand spankin new starter. but anyways i just give it good ole wack with a wrench or something and go to start it and all it good.
Old Jun 20, 2004 | 02:06 PM
Usfrob22's Avatar
Default Re: Wont start, no clicking (Cjsls)
Are 91 Integra's known for having bad igniters in the dizzy? Any chance this could be it or would the car still try to crank over if this was the case...
Old Jun 20, 2004 | 03:43 PM
stasi's Avatar
It's not the distributor, I can almost guarantee that.
Old Jun 21, 2004 | 03:18 PM
gasolina's Avatar
Hello, I have the same problem
I have a 92 LS stock. I parked for a minute, came back and car wouldn't start, no clicking, good batery, good leads...
I jumped the starter , tested the clutch switch, checked the fuse... Is there anything else to look for before I pull out the whole ignition switch and have to pay the $250?
Thankx!
Modified by gasolina at 5:53 PM 6/21/2004
Old Jun 21, 2004 | 05:36 PM
marshallslp's Avatar
push the clutch in
Old Jun 23, 2004 | 04:48 PM
gasolina's Avatar
bump
Old Jun 24, 2004 | 02:36 PM
Keno20's Avatar
I have had this problem also. When I took it to the mechanic, before looking at it he said it was the starter solenoid, but when I got it back he said it ended up being the starter bush.
Keno20's Avatar
Default Re: Wont start, no clicking (Keno20)
(The bush was worn down and needed replacing)
JDM_d15b_eg8
Oct 11, 2007 03:55 PM
RevanDA85
Mar 4, 2007 03:22 PM
Predatorinc
13
Jan 21, 2007 10:18 AM
crx1856
Aug 20, 2003 10:24 PM
