b16a swap - 94 sol
swapping the JDM b16a for the d16z6 in my sol, and been doing quite a bit of research prepping and buying all i need to get started. I already have the complete swap essentials, but I read on a swap guide and it said this: "The B16A won't work on the 92-up vehicles unless you find a compatible grey plug ecu, distributor, and a hydraulic to cable adapter for the transmission." this might be painfully obvious to some of you, or maybe its totally wrong....just wanting some light shed on it by you guys who know this ****. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SICKSOLVTEC-T »</TD></TR><TR><TD CLASS="quote">Sounds like he has an obd0 b16a. Your del sol is obdI. They are not compatible without a lot of hassle.</TD></TR></TABLE>
yes you'll have to do an obd0 to obd1 conversion. not sure, but maybe a hydro to cable transmission conversion also.
Drew555
19
Aug 31, 2011 11:18 AM
BlkB16aEJ
24
Mar 23, 2008 06:29 PM
mongoliandonuts
Dec 20, 2003 08:30 PM
