somethings really wrong.... could use some help.
Old Jun 19, 2004 | 11:35 AM
BlkslowCRX's Avatar
Default somethings really wrong.... could use some help.
Ok about 2 months ago my car (96 ex w/ stock y8 with 128K)started missing between 1500-300 rpms and then it would go away and run fine. i pulled out the plugs and they looked pretty bad. So i replaced them with ngk plugs. It didnt help so i replaced the external msd coil and the plug wires thinking that might help. It didnt. they the other day while i was driving it it started missing all the time. the motors stumbles alot even at idle and the plugs are all black again. so i pulled off the whole ignition system ( msd sci w/ blaster ss coil) and i removed my vafc. But nothing helped. i ran a compression test on the motor and its read as fallows 125,125,110,120 pretty normal rite or should i be conserned about the number 2 cylnder being at 110. i also checked the timing belt to see if it might have skipped a tooth but everything seemed to check out ok. . Any one have any ideas maybe another route that im not thinkin of. thnaks alot.
Edit * i also replaced the fuel filter
Old Jun 19, 2004 | 12:00 PM
RYAN_SJ's Avatar
Default Re: somethings really wrong.... could use some help. (BlkslowCRX)
describe what the spark plugs look like and make sure the comp. test was done correctly. I think the comp.#s should be higher for a stock honda.
Old Jun 19, 2004 | 02:53 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Why do you have a vafc and all that other stuff on a stock engine? Please describe your *exact* setup in every detail.
Old Jun 19, 2004 | 03:35 PM
BlkslowCRX's Avatar
Default Re: somethings really wrong.... could use some help. (tjbizzo)
i ahve a 96 ex with an aem cold air, msd sci ignition w/ blaster ss coil , vafc ,
apex-i n-1 exhaust. i have a turbo set up i was planning on installing but i needed to figure out the missing first. But i rechecked everything the timing belt is off 1-2 teeeth, and the rings are bad.
nonvteclude
May 23, 2009 06:14 PM
jksmith
Jan 5, 2009 11:29 AM
craphatch
Sep 30, 2007 08:38 AM
cdk001
Mar 30, 2006 09:57 PM
gottagofaster
Oct 22, 2005 04:50 PM
