gsr head b20 block, what else would i need ?
i threw a rod and im thinking i need a whole new block. . . i was looking at picking up a new b20 "GOLDEN EAGLE STREET/RACE BLOCK.!!"
what else would i need to change from a stock gsr to make this work ?
would i need new pistons? or rods or a new crank ?
what kinda fuel managment do i need ?
can i still have p/s and a/c with it or no ?
thanks
EDIT: i just notied the bore on a b20 is 84mm thats bigger then the gsr so i would need to get new pistons
im trying to get my car on the road and do a slight all motor build. . .
thanks
alright . . . bump
im thinking maybe of just some cams and pistons and maybe a 50 shot of nos , although im not very keen on nitrious . . .
http://www.c-speedracing.com/h...c.php
thats EVERYTHING you need to know about making a crvtec, hope that helps you
very nice . . . i seems alot like ls/vtec and im not to intrested in that kind of setup , i want power and as much reliability as possible and at the same time i dont have a **** load of money to throw around . . .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jason bouchard »</TD></TR><TR><TD CLASS="quote">i threw a rod and im thinking i need a whole new block. . . i was looking at picking up a new b20 "GOLDEN EAGLE STREET/RACE BLOCK.!!"
thanks
im trying to get my car on the road and do a slight all motor build. . . </TD></TR></TABLE>
you'll need b20 crank, rods, and pistons. You can use your gsr ecu and a vafc or hondata as fuel management.
You can still use p/s, and a/c.
thanks
PinoyShadow
28
Oct 11, 2011 10:11 PM
