Replacment antenna?
It is very easy to remove an antenna from our model. On the top is a cap that is screwed on. You may need to use a pair of needlenose pliers to remove it. Next, you have to remove the interior paneling and you will see two (2) nuts that you will have to remove with a 10mm. Then there is a a hose that displaces water remove that, the power source clip remove that as well, then you have to remove the antenna. Now for the AutoZone unit it has more wiring (5+ wires) Vs. Stock 3 wire source. Also, it doesnt have the same bolt up as the stock. So its up to you, if you wish to rewire it with the AutoZone $40 unit
or just try and get another stock unit. My advise is you get a a good used working unit to make it simple and easy.
rice a roni
May 31, 2006 11:48 AM
