fuel injectors
Old Jun 19, 2004 | 11:10 AM
RABBIT9's Avatar
Default fuel injectors
I know that there has to be a FAQ around here somewhere on honda fuel injectors. I nee to know the specs for different models, so I can compare injectors.
My search efforts have not yielded the desired information
Can somebody point me in the right direction?
Old Jun 19, 2004 | 12:44 PM
ZigenBallz's Avatar
Default Re: fuel injectors (RABBIT9)
Long time no see Rabbit...
Anyways... as far as I remember most if not all OBD1 peak and hold Honda injectors are 240cc with the exception of the H22A lude injectors, which are 345cc...
Old Jun 19, 2004 | 01:48 PM
jakeiscool's Avatar
Banned
Default Re: fuel injectors (ZigenBallz)
F22b injectors are 235ccs i think
Old Jun 19, 2004 | 01:54 PM
fw190bvi's Avatar
Default Re: fuel injectors (JakeIsCool)
all you need to know and more
Old Jun 20, 2004 | 04:20 AM
RABBIT9's Avatar
Yeah ZigenBallz, with all the problems I had with my last mechanic, not to mention the GUDE fiasco ( https://honda-tech.com/zerothread?id=518696 ), it kind of took all the fun out of it. I had a real money pit on my hands just trying to keep the car on the road. I know that I'm running lean at the top, and I'm just finally getting around to working on it.
Modified by RABBIT9 at 9:25 PM 6/24/2004
Old Jun 24, 2004 | 05:23 PM
RABBIT9's Avatar
Okay, just said F'it and ordered the parts.
Walboro 255lph fuel pump
AEM fuel rail
RC 320cc injectors
-as well as a replacement for my broken FP guage and a new fuel filter and vacuum lines.
To add to the current set up:
Injen intake, Gude TB , port matched IM, Port Flow head, Ferrea valvetrain, AEM cam gear, AEM FPR, Knology ignition, Wiseco 11:1 pistons, Crower bilet rods, DC SS header, GREDDY EVO exhaust.
I'll slap this crap in, and head up to P1 for the SAFC install and some dyno time.
Here we go again.
Old Jun 24, 2004 | 05:38 PM
Calean007's Avatar
As kind of a sidebar to this(because I didn't think it warranted another thread), I'm going to be inspecting my fuel injectors here soon when I'm doing all my other preventative maintenance, but I have a question. Are fuel injectors something you just clean off when they have carbon on them, like what Chilton's says, or is there a certain period in years where one might want to replace them altogether? The book didn't really go into detail, so I'm of the opinon you don't replace them unless they just aren't working period.
any guidance would help.
Old Jun 24, 2004 | 05:49 PM
RABBIT9's Avatar
Default Re: fuel injectors (Calean007)
I don't think that you can "wear out" a fuel injector. What usually happens is that varnish from the fuel clogs the injector. You can have your injectors professionally (ultrasonic) cleaned to remove the varnish and restore performance. I think that there were several places / people on the board that would clean them for around $15/per.
When you modify your stock engine (High CR / FI / Nitrous), you will reach the point where your stock injectors will not provide all the needed fuel; that's the reason for the upgrade.
Old Jun 24, 2004 | 08:12 PM
wongf22b2's Avatar
Default Re: fuel injectors (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">all you need to know and more</TD></TR></TABLE>
boostedteg4dr
May 5, 2009 02:57 PM
mnhotrod2003
Sep 23, 2005 11:31 PM
Bintegra
14
Jul 29, 2004 08:11 PM
ludelvr
Mar 18, 2002 05:58 AM
