ac on a EG with a b18c1 motor in it
Old Jun 19, 2004 | 10:19 AM
bankhead83's Avatar
Default ac on a EG with a b18c1 motor in it
hello I came here asking about what did I need to put ac on my car people told me a p54 ac bracket came on the honda del sol si, but this kid told me that the honda del sol si is only the single cam vtec, Del Sol Models:
1.5 SOHC non vtec = s
1.6 SOHC Vtec = si
1.6 DOHC Vtec = vtec
what bracket out of those 3 del sol do I need to put ac on my 92 civic with gs-r motor swap, I need to know ASAP
Old Jun 19, 2004 | 10:20 AM
Hybrid96EK's Avatar
Default Re: ac on a EG with a b18c1 motor in it (bankhead83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bankhead83 &raquo;</TD></TR><TR><TD CLASS="quote">hello I came here asking about what did I need to put ac on my car people told me a p54 ac bracket came on the honda del sol si, but this kid told me that the honda del sol si is only the single cam vtec, Del Sol Models:
1.6 SOHC Vtec = si
what bracket out of those 3 del sol do I need to put ac on my 92 civic with gs-r motor swap, I need to know ASAP</TD></TR></TABLE>
Get the bracket that is from the Del Sol Vtec. Its stamped "P54". You can also use a JDM ITR alumn one if you want to tsave some weight.
Old Jun 19, 2004 | 10:31 AM
miahmouse's Avatar
edit:bracket fits b series engine and the compressor. the other ones will probably be the same as the stock one.
Old Jun 19, 2004 | 07:47 PM
nimblecivic's Avatar
like hybrideg said, you want the delsol vtec p54 bracket...that's what I'm lookin' for because it will mate a d series compressor to a b series block....you can also use a crv bracket..believe it's stamped p7h....at least that's what I've read...anyone confirm or deny this....If it will work I might be able to find one of those a little cheaper than a p54.....
CivicTT
Jul 19, 2010 11:22 AM
ATrin
12
Jul 22, 2006 08:47 AM
CopperSol
Jul 8, 2005 01:08 PM
Poey2
Mar 17, 2004 07:26 AM
