Please Help!!! Questions about Engine Overheating!?!?!?!?!?!
I own a 1996 Accord with 97,000 miles. Recently, my car has been overheating when idling and while using the AC. I also have a leak in the anti-freeze, I don't know if these are corillated or not. If anyone could help with any information on what could be the cause, it would be greatly appreciated.
Thankyou,
Rob
Thankyou,
Rob
You need to find out where the coolant is leaking and fix it. The car will run hotter with the A/C on because the condensor is putting out the heat in front of the radiator.
Fill up the coolant and burp the block via the 12mm bleed screw at the T-stat housing.....then start the car and find the coolant leak.
